TitleBlock
TitleBlock
Message 1 of 11
TitleBlock
HI, I am new in revit api
I have a sheet with a titleblock family
Family have shared parameters
i want to write a vb.net procedure that read the value of parameters. Where I can find a sample?
thanks
Replies (10)
Message 2 of 11
Joe.Ye
Hi Scarta,
You can use the shared paramter name to get the parameter , then read the parameter value.
Here is the code snippet to show how to read the shared parameter value from the title block.
<TransactionAttribute(Autodesk.Revit.Attributes.TransactionMode.Manual)> _
Public Class RevitCommand2
	Implements IExternalCommand
	Public Function Execute(commandData As ExternalCommandData, ByRef messages As String, elements As ElementSet) As Result
		Dim app As UIApplication = commandData.Application
		Dim doc As Document = app.ActiveUIDocument.Document
		Dim sel As Selection = app.ActiveUIDocument.Selection
		Dim ref1 As Reference = sel.PickObject(ObjectType.Element, "Please pick title block")
		Dim tb As FamilyInstance = TryCast(doc.GetElement(ref1), FamilyInstance)
		'''title block is a FamilyInstance
		If tb Is Nothing Then
			Return Result.Failed
		'If the target shared parameter is from the family symbol/ family type.
		Dim param2 As Parameter = tb.get_Parameter("SharedParameterName")
		'If the target shared parameter is from the family instance.
		'Parameter param = tb.get_Parameter("SharedParameterName"); //directly use the shared parameter name
		'show the fire rating in task dialog
		TaskDialog.Show("target shared parameter value", param2.AsString())
		Return Result.Succeeded
	End Function
End Class
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Message 3 of 11
HI,..
thanks I will try it!!
Message 4 of 11
i receive an error on the line tb.get_parameter the vb editor say "is not a member of autodesk.revit.db.familyistance"
any idea?
Message 5 of 11
Joe.Ye
Sorry, I used the code converter to convert the C# to VB.net. The code was not converted completely correct.
Here is the one should work.
		Dim param2 As Parameter = tb.Parameter("SharedParameterName")
		'Parameter param = tb.Parameter("SharedParameterName"); //directly use the shared parameter name
	End Function
End Class
Joe Ye
Contractor
Message 6 of 11
HI...
I have a problem with this line:
vb editor say "Can not use Parameter as expression" and param is not declared
Message 7 of 11
Joe.Ye
Hi Scarta,
Please remove the get_  from below line.
VB.NET doesn't need the get_ for when calling the class get properties.
Joe Ye
Contractor
Message 8 of 11
hi,
I have removed the _get but the problem is Parameter param, the error is: "Parameter is a type that can not be use as espression"
I post he total code:
Region
"Imports"
' Import the following name spaces in the project properties/references.
' Note: VB.NET has a slighly different way of recognizing name spaces than C#.
' if you explicitely set them in each .vb file, you will need to specify full name spaces.
'Imports System
'Imports Autodesk.Revit.DB
'Imports Autodesk.Revit.UI
'Imports Autodesk.Revit.ApplicationServices ' Application class
'Imports Autodesk.Revit.Attributes ' specific this if you want to save typing for attributes. e.g.,
'Imports Autodesk.Revit.UI.Selection ' for selection
Imports
Revit.Util.Constant
Imports
Revit.Util
Imports
System.Reflection
#End
Region
#Region
"Description"
' Revit Intro Lab - 2
' In this lab, you will learn how an element is represended in Revit.
' Disclaimer: minimum error checking to focus on the main topic.
#End
Region
'<Autodesk.Revit.Attributes.Regeneration(Attributes.RegenerationOption.Manual)>
'<Autodesk.Revit.Attributes.Transaction(Attributes.TransactionMode.Manual)>_
'<TransactionAttribute(Autodesk.Revit.Attributes.TransactionMode.Manual)> _
Transaction(TransactionMode.Automatic)> _
Public
ClassRevitCommand2ImplementsIExternalCommand
PublicFunctionExecute(commandDataAsExternalCommandData, ByRefmessagesAsString, elementsAsElementSet) AsResult_
ImplementsIExternalCommand.ExecuteDimappAsUIApplication = commandData.ApplicationDimdocAsDocument = app.ActiveUIDocument.DocumentDimselAsSelection = app.ActiveUIDocument.SelectionDimref1AsReference = sel.PickObject(ObjectType.Element, "Please pick title block")
DimtbAsFamilyInstance = TryCast(doc.GetElement(ref1), FamilyInstance)
IftbIsNothingThenReturnResult.FailedEndIf
'If the target shared parameter is from the family symbol/ family type.DimSh_NameAsParameter = tb.Parameter(BuiltInParameter.SHEET_NAME)
DimSh_NumberAsParameter = tb.Parameter(BuiltInParameter.SHEET_NUMBER)
DimSh_ScaleAsParameter = tb.Parameter(BuiltInParameter.SHEET_SCALE)
DimparamAsParameter
'Dim param2 As Parameter = tb.Parameter("D2")'If the target shared parameter is from the family instance.Parameterparam = tb.Parameter("D2") '//directly use the shared parameter name
'show the fire rating in task dialog'TaskDialog.Show("target shared parameter value", param2.AsString())ReturnResult.Succeeded
End
Class
Message 9 of 11
hI..with this procedure i can retrieve built in parameter but when I check value for shared parameter i retrieve "nothing"
I have used bitchecker with the title block, but I not retrieved any shared parameter...
please download rvt file from http://www.fxcrender.com/download/u17.zip
this is the code: and i upload the rvt file
#Region "Imports"
'Imports System
Imports Revit.Util.Constant
Imports Revit.Util
Imports System.Reflection
#End Region
#Region "Description"
#End Region
<Transaction(TransactionMode.Automatic)> _
    Public Function Execute(commandData As ExternalCommandData, ByRef messages As String, elements As ElementSet) As Result _
        Implements IExternalCommand.Execute
        Dim Sh_Name As Parameter = tb.Parameter(BuiltInParameter.SHEET_NAME)
        'Dim Sh_Number As Parameter = tb.Parameter(BuiltInParameter.SHEET_NUMBER)
        'Dim Sh_Scale As Parameter = tb.Parameter(BuiltInParameter.SHEET_SCALE)
        'D2 is a shared parameter
        Dim param As Parameter = tb.Symbol.Parameter("D2") '//directly use the shared parameter name
        TaskDialog.Show("target shared parameter value", Sh_Name.AsString())
    End Function
End Class
Message 10 of 11
Can anyone help me?
I have installed Bitchecker and Revitlookup for check parameters, but the shared paramed are not show
Message 11 of 11
Hi..
Ihave resolved the problem....I was finding the shared parameter on the Title block family, but sp was on the SHEET family!!
Thanks for your help!!
Stefano
