The application is in break mode - Visual Studio
Omar_Amen
Omar_Amen
Hi there,
I have this issue on debugging any code with Revit :'(
I spent two days searching and trying a lot of solutions in the forum and stack overflow, but unfortunately the issue still exist and can't solve it 😞
I can't debug any thing with this issue
jeremy_tammik
I would suggest trying to start Revit in the debugger with no add-in loaded. If it still crashes, wow. If not, continue.
Then, start Revit in the debugger with a minimal one-liner add-in loaded. If it still crashes, wow. If not, continue.
Then start Revit in the debugger with your problematic add-in loaded. If it crashes, good, you know that your add-in is causing it.
Once that is established, back off again. Remove all your add-in code. Ensure no crash.
Add code back again line by line, and debug step by step until the crash reappears.
Congratulations. You have found the culprit.
Omar_Amen
Thanks Jeremy, you are my hero ❤️
It worked after removing all the loaded add-ins from the addins folder and I found that the cause of the issue is an addin I've just installed last week and it located in the Autodesk plugin folder (C:\ProgramData\Autodesk\ApplicationPlugins)
and every thing is working smoothly after removing it,
after trying tons of solutions I thought it can't be solved!
thanks Jeremy, you saved me 😅
kunal.jadhavE3VCB
Observer
Observer
Hello @jeremy_tammik,
I am facing the same issue in my C# consle app. and I noticed the issue is in Autodesk.Navisworks.Api this API is loaded from Autodesk Manage 2021. I cannot remove it as it is required for my code. Please guide me way ahead.
My plan here to use new Autodesk API instead of ComApi.
Attached my code + Reference Snap Shot
Note - I am a new developer to C# and Autodesk Manage too.
I hope I will be able to solve this issue.
Thanks and best regards
Kunal
