TextNoteOption class VerticalAlignment property missing
zhuliyi0
zhuliyi0
Using Revit API 2020. TextNoteOptions.VerticalAlignment property is missing. It is documented in the .chm file.
See screenshot below.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @zhuliyi0 ,
VerticalAlignment is working fine in Revit 2020.
Are you still getting the error after setting a value for vertical alignment?
What does visual studio show when you place your cursor over the vertical alignment?
What error are you getting when you try to build the solution?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Revitalizer
I bet you are referencing an older version of RevitAPI.dll.
No VerticalAlignment property in Revit 2018.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
