Export LightNode Information
Hello All.
I am trying to export LightNode information so I can use it in a custom application.
Right Now I have prototyped this:
 public void OnLight(LightNode node)
#if _2018
            var lpcd = node.GetAsset()["lightProfileCacheData"] as AssetPropertyString;
#else
            var lpcd = node.GetAsset().FindByName("lightProfileCacheData") as AssetPropertyString;
#endif
            Transform lightTrf = node.GetTransform();
            LightOptions newLight = new LightOptions();
            newLight.name = node.NodeName;
            newLight.pos = lightTrf.Origin;
            newLight.angle = lightTrf.BasisX;
            if (lpcd != null)
               byte[] data = Encoding.Unicode.GetBytes(lpcd.Value);
                newLight.path = System.Text.Encoding.UTF8.GetString(data);
            if (!lights.Contains(newLight)) lights.Add(newLight);
//LightOption Class
 public class LightOptions
        public XYZ pos;
        public XYZ angle;
        public string name;
        public string path;
        public string iesName;
However, I am trying to get the light direction, spotlight angle and some of the other metadata attached to a lightNode. Unfortunately the documentation does not lead me anywhere.
Any ideas?
I need to convert these XYZ's to Vector3's in Unity3D so all conversion is to Unity's default 1m:1Unit
