Wall.FindInserts() doesnt working
Hi! Im trying to get wall openings. but FindInserts method can't find the opening in wall. There is my code:
var openings=wall.FindInserts(true,false,false,false);
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
1)Start the transaction
2)Delete the wall.
3)Collect the deleted elementIDS
4)roll back the transaction
5)from the deleted elementsIDS get the element "OPENING"
 Transaction firstTransaction = new Transaction(doc);
 firstTransaction.Start("FIRST");
//GET ELEMENTID OF WALL
ElementId Wall_ID;
IList<ElementId> wallIDS = new List<ElementId>();
wallIDS.Add(Wall_ID);
IList<ElementId> deletedEIDS = doc.Delete(wallIDS) as IList<ElementId>;
firstTransaction.RollBack();
 IList<Element> openingElements = new List<Element>();
                foreach(ElementId openingID in deletedEIDS)
                    Element elements_in_wall= doc.GetElement(openingID);
                    if(elements_in_wall.Name.Contains("Opening"))
                        openingElements.Add(elements_in_wall);
 now this list IList<Element> openingElements will contain all the opening elements.
Also you can try using the below link
https://thebuildingcoder.typepad.com/blog/2015/12/retrieving-wall-openings-and-sorting-points.html
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thanks, I'll try it.
