TaskDialog user input
dwightduronidavy
Message 1 of 15
dwightduronidavy
Dear all,
The following application macro (for Revit 2024) does not allow the user to input using the TaskDialog function.
I would appreciate a resolution concerning this matter.
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace DDA_CSharpModule4
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.DB.Macros.AddInId("8469C11C-9426-4B76-8910-02E720C07230")]
    public partial class ThisApplication
        private void Module_Startup(object sender, EventArgs e)
        private void Module_Shutdown(object sender, EventArgs e)
        #region Revit Macros generated code
        private void InternalStartup()
            this.Startup += new System.EventHandler(Module_Startup);
            this.Shutdown += new System.EventHandler(Module_Shutdown);
        #endregion
        public void RotateModelFileAboutIO()
            UIDocument uidoc = this.ActiveUIDocument;
            Document doc = uidoc.Document;
            // Prompt the user for the rotation angle in degrees using a TaskDialog
            TaskDialog angleDialog = new TaskDialog("Rotate Model File About Internal Origin");
            angleDialog.MainInstruction = "Enter the angle (in degrees) to rotate the model:";
            angleDialog.MainContent = "Please enter a numeric value for the angle.";
            angleDialog.CommonButtons = TaskDialogCommonButtons.Ok | TaskDialogCommonButtons.Cancel;
            angleDialog.DefaultButton = TaskDialogResult.Ok;
            TaskDialogResult result = angleDialog.Show();
            if (result == TaskDialogResult.Cancel)
                TaskDialog.Show("Info""Operation cancelled by user.");
                return;
            // Here, we assume the user can input the value using a better method or predefined angles
            double rotationAngleDegrees = 0;
            // Alternatively, a list of predefined angles can be added for selection.
            // Convert the rotation angle to radians
            double rotationAngle = rotationAngleDegrees * (Math.PI / 180.0);
            // Get the internal origin point as the center of rotation
            XYZ centerPoint = XYZ.Zero;
            // Define the rotation axis (Z-axis)
            Line rotationAxis = Line.CreateBound(centerPoint, centerPoint + XYZ.BasisZ);
            // Collect all elements that can be transformed
            FilteredElementCollector collector = new FilteredElementCollector(doc)
                .WhereElementIsNotElementType();
            List<ElementId> elementIds = new List<ElementId>();
            foreach (Element element in collector)
                // Skip certain elements that are not transformable (e.g., levels, views, phases, grids)
                if (!(element is Level) && !(element is View) && !(element is Phase) && !(element is Grid))
                    elementIds.Add(element.Id);
            // Start a transaction to rotate the model
            using (Transaction transaction = new Transaction(doc, "Rotate Entire Model"))
                try
                    transaction.Start();
                    // Rotate all collected elements around the internal origin
                    ElementTransformUtils.RotateElements(doc, elementIds, rotationAxis, rotationAngle);
                    transaction.Commit();
                    TaskDialog.Show("Success"string.Format("The model has been successfully rotated by {0} degrees about the internal origin.", rotationAngleDegrees));
                catch (Exception e)
                    transaction.RollBack();
                    TaskDialog.Show("Error"string.Format("An error occurred while rotating the model: {0}", e.Message));
Replies (14)
Message 2 of 15
scgq425
Hi @dwightduronidavy :
Taskdialog just a prompt text window , if you want to get user input paramater value , can use the ` Microsoft.VisualBasic.Interaction.InputBox` API top make this style like the picture.
this dll reference import from `Microsoft.VisualBasic.dll`
and i edit you code , also have some problem.
1. you function not use in startUp
2. the activeDocuemnt patameter can get quicky.
    [Autodesk.Revit.DB.Macros.AddInId("7F17BF95-744C-4A32-9E1E-79457755021B")]
    public partial class ThisDocument
            RotateModelFileAboutIO();
        #endregion
            UIDocument uidoc =  Application.ActiveUIDocument;
            string degreeStr = Microsoft.VisualBasic.Interaction.InputBox("input value" , "Rotate","0");
            TaskDialog.Show("Revit" , degreeStr);
            // This is Code
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
Message 3 of 15
scgq425
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 4 of 15
dwightduronidavy
Thank you so very much!
Would it be at all possible for you to paste the entire macro code here?
I am fairly new to RevitAPI..
Message 5 of 15
scgq425
 i just add tow row target to create window to get the user input .
do you want to check or debug you code to done this function?
1. the input window about :
2.  Get ActiveDocument
in Revit macro this is vaild .
just use Appliication can direction get .
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 6 of 15
dwightduronidavy
This is my attempt (but with errors [attached])
using System;
using System.Linq;
using Microsoft.VisualBasic; // Importing Microsoft.VisualBasic for InputBox usage
RotateModelFileAboutIO(); // Call RotateModelFileAboutIO on startup
#endregion
UIDocument uidoc = this.Application.ActiveUIDocument;
string angleInput = Interaction.InputBox("Enter the angle (in degrees) to rotate the model:", "Rotate Model File About Internal Origin", "0");
if (!double.TryParse(angleInput, out double rotationAngleDegrees))
TaskDialog.Show("Error", "Invalid angle entered. Please enter a numeric value.");
return;
try
TaskDialog.Show("Success", string.Format("The model has been successfully rotated by {0} degrees about the internal origin.", rotationAngleDegrees));
catch (Exception e)
TaskDialog.Show("Error", string.Format("An error occurred while rotating the model: {0}", e.Message));
Message 7 of 15
Mohamed_Arshad
Kindly follow below steps.
  1. Add Microsoft.VisualBasic reference to the project
  2. Call Input Box Method and pass the parameters.
string angleInput = Microsoft.VisualBasic.Interaction.InputBox("Enter the angle (in degrees) to rotate the model:","Rotate Model File About Internal Origin","0");​
Complete Code for Reference (Errors Resolved)
			string angleInput = Microsoft.VisualBasic.Interaction.InputBox("Enter the angle (in degrees) to rotate the model:", "Rotate Model File About Internal Origin", "0");
			double rotationAngleDegrees;
			if (!double.TryParse(angleInput, out rotationAngleDegrees))
					return;
				try
				} catch (Exception e)
 Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
Message 8 of 15
scgq425
this is my code , can be run in revit .
you code problem is the reference not import
you can try this or  @Mohamed_Arshad code to test .
 * Created by SharpDevelop.
 * User: MainUser
 * Date: 2024/12/2
 * Time: 20:57
 * To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using System.Linq;
namespace A
    [Autodesk.Revit.DB.Macros.AddInId("928B9B42-B28E-44C3-ACD5-32E2DB224F2C")]
        #endregion
string angleInput = Microsoft.VisualBasic.Interaction.InputBox("Enter the angle (in degrees) to rotate the model:""Rotate Model File About Internal Origin""0");
double rotationAngleDegrees = 0.0D;
bool hasTry = double.TryParse(angleInput , out rotationAngleDegrees);
if (!hasTry){
TaskDialog.Show("Error""Invalid angle entered. Please enter a numeric value.");
return;
try
catch (Exception e)
LanHui Xu 徐兰辉
Blog
LinkedIn
Message 9 of 15
dwightduronidavy
Thank you so much Mohamed. I followed your instructions (imported the VB ref) - but got the following error after executing the code:
After adding the two missing '}', i received the following error:
'Autodesk.Revit.ApplicationServices.Application' does not contain a definition for 'ActiveUIDocument' and no extension method 'ActiveUIDocument' accepting a first argument of type 'Autodesk.Revit.ApplicationServices.Application' could be found (are you missing a using directive or an assembly reference?) (CS1061) - C:\ProgramData\Autodesk\Revit\Macros\2024\Revit\AppHookup\DDA_CSharpModule4\Source\DDA_CSharpModule4\ThisApplication.cs:34,40
Message 10 of 15
Mohamed_Arshad
Try create a new project and test the code. It is executing in my end with no errors.
Mohamed Arshad K
Message 11 of 15
dwightduronidavy
Hi Mohamed,
This is the new application macro:
using System;
using System.Linq;
namespace DDA_CSharpModule5
    [Autodesk.Revit.DB.Macros.AddInId("124C2055-E328-4AFD-9D93-C52935B8BE8A")]
        #endregion
                    return;
                try
Error message:
'Autodesk.Revit.ApplicationServices.Application' does not contain a definition for 'ActiveUIDocument' and no extension method 'ActiveUIDocument' accepting a first argument of type 'Autodesk.Revit.ApplicationServices.Application' could be found (are you missing a using directive or an assembly reference?) (CS1061) - C:\ProgramData\Autodesk\Revit\Macros\2024\Revit\AppHookup\DDA_CSharpModule5\Source\DDA_CSharpModule5\ThisApplication.cs:34,40
Message 12 of 15
Mohamed_Arshad
It seems mismatching reference kindly replace code snippet at below the method.
Snippet-01
UIApplication uiapp= new UIApplication(this.Application.Application);
UIDocument uiDoc=uiapp.ActiveUIDocument;
Mohamed Arshad K
Message 13 of 15
dwightduronidavy
Hi Mohamed, i got the below error:
Message 14 of 15
Mohamed_Arshad
Try check below code snippet
Code Snippet
UIApplication uiapp= new UIApplication(this.Application);
UIDocument uidoc=uiapp.ActiveUIDocument;
Document doc= uidoc.Document;
Mohamed Arshad K
Message 15 of 15
dwightduronidavy
PERFECT! Thank you so very much Mohamed and  scgq425
