How to query information from Revit while it is in transaction mode.
quang.nguyenrauchanvit
I have an external event that call GetZoomCorner() every second and send that information to my application. However, when Revit enters transaction mode(e.g., as shown in the picture where I am drawing a grid, Revit enters transaction mode), the external event stops working because the Revit main thread is busy. Is there a way to fetch information even when Revit is busy?
scgq425
Hi @quang.nguyenrauchanvit :
use the idling event to put you operation when revit is not busy in thread .
this is a page to introduce and set a sample code to use it
Replacing an Idling Event Handler by an External Event
LanHui Xu
ricaun
There is no way, if Revit is busy you need to wait the command to finish.
Both Idling and External Event does not trigger when Revit is busy running a command.
I wonder why you need to fetch Revit each second.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
