Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
taskDialog.Show cut off
2 REPLIES 2
mliuAP3CU
222 Views, 2 Replies
I have been using TaskDialog.Show() to check my code.
When the window pops up, the message is cut off and I can't extend the window to show the whole message.
Is there a way to make the window bigger to see the whole message? Or another better way to see the message?
(using c# to code)
(also not showing a list but that's a different problem)
This is the code I have been using:
FilteredElementCollector levCollector = new FilteredElementCollector(revitDoc);
List
<Level> levelsCollection = levCollector.OfClass( typeof( Level ) )       .OfType<Level>()       .OrderBy( lev => lev.Elevation )       .ToList();
string stringCollection = levelsCollection.ToString();
TaskDialog.Show("Something",stringCollection);
 screenshot to show problem.
2 REPLIES 2
Mohamed_Arshad
in reply to: mliuAP3CU
HI @mliuAP3CU
ToString() can't work for List, It will return only System.Generic.Collection.
The thing is In the Level class we have no of properties, So not able to convert the List<Level> to String. we need to Select Property which needs to convert as one string variable. Kindly refer to the below code for additional reference.
            List<Level> levelsCollection = levCollector.OfClass(typeof(Level))
                  .OfType<Level>()
                  .OrderBy(lev => lev.Elevation)
                  .ToList();
            string stringCollection = string.Empty;
            foreach(Level level in levCollector)
                stringCollection += level.Name + " " + level.Elevation * 304.8+"\n";
            TaskDialog.Show("Something", stringCollection);
Reference Image:
Few Links
URL: https://stackoverflow.com/questions/4981390/convert-a-list-to-a-string-in-c-sharp
https://stackoverflow.com/questions/15945924/how-do-i-convert-listclass-to-string
Hope this Helps 🙂
Thanks & Regards,
Mohamed Arshad K
try
  List<Level> levelsCollection = levCollector.OfClass( typeof( Level ) )
        .OfType<Level>()
        .ToList();
catch (Exception ex)
  MessageBox.Show(ex.Message)
  return Result.Cancelled;
Forma Design Contest
Rail Community
