Dear All,
I have recently upgraded to Revit 2022
Weirdly, I don't see structural part in Revit 2022.
I appreciate if you can help me.
Thank you,
Amir
Solved by jeremy_tammik. Go to Solution.
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to licensing, installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
