Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
split selected 2d lines into closed loops to create separate filled regions
1 REPLY 1
FrankHolidaytoiling
313 Views, 1 Reply
I would like to split selected lines in a family into 1 or more curveLoops to add to a collection and iterate over creating filled regions.
I can achieve this for one curved loop after implementing code solutions from the Building coder blog, however I was wondering what the best approach if I get lines from a selection rectangle over the lines in 2d.
Each shape within the selection window would be a separate filled region, an even more automatic method might be to use a collector of all lines in view and convert them into filled regions if they have closed loops?
Labels (5)
1 REPLY 1
I would suggest that the answer is Yes.
I hope this helps 🙂
Maybe do some research on how to detect closed loops in a given collection of line segments, e.g., search the Internet for things like "geometry find closed loop line segment":
https://duckduckgo.com/?q=geometry+find+closed+loop+line+segment
