Split Face Tool in Modify Tab Method Revit API
mr.engineer.aec
mr.engineer.aec
 Hi guys,
I'm trying use Split Face Tool in Modify Tab but i can't find any method Revit API.
I only find FacePlitter but seem it only get boudaries of face which splited.
How can i solved this issue ?
Many thanks.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @mr.engineer.aec ,
You can use SplitFace Postable command
also, check this below link
https://forums.autodesk.com/t5/revit-api-forum/postablecommand-splitface-and-splitsurface/td-p/96319...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
mr.engineer.aec
 Hi @naveen.kumar.t
Thank for your help.
Do you have example for method split face button ?
Many thanks.
