SpatialElementTag class
echeverrimontes
echeverrimontes
Hello, I've been trying to change an AreaTag (SpatialElementTag class) by the following method:
 import clr
clr.AddReference('RevitServices')
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
clr.AddReference('RevitAPI')
import Autodesk
from Autodesk.Revit.DB import *
from Autodesk.Revit import DB
doc = DocumentManager.Instance.CurrentDBDocument
#areaTags = UnwrapElement(IN[0])
type = IN[1]
areaType = IN[2]
out = []
ids = []
typeIds = []
parameters = []
areaTags = FilteredElementCollector(doc, doc.ActiveView.Id).OfClass(SpatialElementTag)
for areaTag in areaTags:
    id = areaTag.GetTypeId()
    out.append(id)
    validTypes = GetValidTypes(doc, areaTag)
out.append(validTypes)
a = Transaction(doc, 'Set Spatial Element Tag')
a.Start()
for tag in areaTags:
    for t in tag:
        t.ChangeTypeId(validTypes[2])
a.Commit()
OUT = out
It seems the methods GetValidTypes() and ChangeTypeId()  are not valid names and are unrecognizable although they appear within the API, I can't find where am I missing a reference or a library.
Thank you very much,
Paula Echeverri Montes
jeremy_tammik
Your code looks ok to me rom a pure Revit API point of view. So, maybe your problem is Python related. If so, you might have more luck resolving it in the Dynamo forum:
echeverrimontes
Thank you jeremy, I'll do so.
Paula EM
