Transform face
Transform face
miguel_tamaraMXF93
Transform face
miguel_tamaraMXF93
I want to know if I can transform a Face using a Transform instance:
    public Face TransformFace(Face face)
        var feetToMeters = 0.3048;
        Transform scaleTransform = Transform.Identity;
        scaleTransform.set_Basis(0, scaleTransform.BasisX.Multiply(feetToMeters));
        scaleTransform.set_Basis(1, scaleTransform.BasisY.Multiply(feetToMeters));
        scaleTransform.set_Basis(2, scaleTransform.BasisZ.Multiply(feetToMeters));
        // Transform the face
thanks in advance.
Moustafa_K
I think you need to transform the whole solid not the face. and then you can get a transformed face. you can achieve that using the static SolidUtils
var transformedSolid = SolidUtils.CreateTransformed(mySolid, mytransform);
then you can get the face from the transformed solid.
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
miguel_tamaraMXF93
Hello Moustafa,
Thank you for replying! Yes, that works, but let me explain.
I get the face using PickObject. And as you may know, getting the element geometry solids, then finding the solid with the face, transforming it, etc etc, seems more like a workaround, not a straightforward solution.
I wish there was something like a FaceUtils in the API.
In any case, thanks for your help!
Moustafa_K
So glad that this working around deleviers you what you are after. A straight forwarded implementation is a golden wish for every developer. Till then the answer will mostly be in the working around, and how smartly we use the available tools. 🙂
Moustafa Khalil
