Hi Jeremy,
Thank you for your insight. I agree with your opinion. It seems the main conclusion would be that we cannot re-use the code, when changing an employer unless granted a permission (license?).
I wonder what happens when we have to re-write an Add-in with the same/similar functionalities as the Add-in at previous workplace. Would you say our insight into previous work could potentially count as an infringement of a Copyright? (or would be in case of a presence of an NDA, which would rarely be present in these scenarios)
In case of work for contract, I don't think the situation is as clear-cut. For instance, from https://asp-software.org/www/misv_resources/business-articles/who-owns-the-code/
Courts and legal analysts use a three-part test to determine whether the developer or the client owns a particular segment or module of code. First, the work must have been specially ordered or commissioned. Second, the work must specifically fall within one of the ten categories enumerated in part (b) of the "work-made-for-hire" rule. If the work at issue does not fall within one of the enumerated categories, it cannot ever be a "work-made-for-hire." Almost all software code is consumer-facing code and will fall under category three, audio-visual work, although some software without a human-readable interface may not fall under any of the ten enumerated categories. Third, and most significant, a commissioned and copyrightable work will only be considered "work-made-for-hire" owned by the client if the parties have a written agreement signed by the developer that explicitly states that the work is "work-made-for-hire."
The highlighted parts leave the employers (or rather Clients) in a bit of a vulnerable position in my opinion. Especially, when the contractor/consultant was hired for architectural duties, rather than software development.
In such cases I would liken said software to a scaffolding that the roofing contractor erects to change the roof. The scaffolding doesn't by default belong to the homeowner. (I do realise this analogy may be flawed)
Also, regarding your last point, there also seem to be some leeway, as per this source https://www.mcgregorlegal.eu/947-2/
Generally, to prove his ownership the employer has to establish that the software has been written by his employee, whose employment characteristic include duties of development of software, and that there is not an agreement that the copyright remains with the employee. It is possible, however, that the employee has made its own software after work or at weekends and that the employer pretends ownership in it, because the person is his employee and has used company’s equipment. In this case it would be decisive whether the employer has ordered the creation and delivery of this type of software to his employee – if not, then the copyright could be with the developer, although he has been in employment relationship at that time. In the opposite scenario, even if the employee has written the software outside his working hours and at his own equipment, in case that his employment duties include the development of similar programs, then the copyright will probably vest in the employer. It is, therefore, advisable to define clearly the duties of the employee and to provide expressly in his employment contract clauses governing the copyright in the results from his work.
So it seems even employer-employee relationship does not guarantee the code ownership to either party and could be considered on case-by-case basis.
In my case, I do most of my coding either during my lunch hour or after work, as I am, in most cases, not being given time for software development by the company I do the work for (there were few exceptions, when software development work was explicitly requested, once I demonstrated what could be achieved with a bit of C#). Seeing as I am a contractor as well, you can see why the whole topic sparked my interest.
I think this whole Copyright thing is an important issue to be aware of, when entering a contract, which I do not believe many people realise. (Sadly, me included.)
Karol
