Sorting a BindinSource
Hello all.  I was wondering if anyone could help me with sorting a bindingsource.  In the Revit SDK samples, there is project called LevelsProperty.  It has a datagridview linked to bindingsource1 that gets filled with Revit Level information.  I would like to keep the datagridview sorted by "Elevation" but I can't figure out how to do this.  By reading online, the bindingsource should be able to be sorted by using the line below but this doesn't seem to do anything.
bindingSource1.Sort = "Elevation DESC";  // doesn't work and does not produce an error
Any ideas?
jeremytammik
Dear Jdean,
Thank you for your query.
This is not really a Revit API query, of course.
It is a pure .NET issue.
Have you read the Microsoft documentation on the BindingSource.Sort property?
http://msdn.microsoft.com/en-us/library/system.windows.forms.bindingsource.sort(v=vs.110).aspx
It specifies a pre-requisite: "To support sorting, the underlying list must implement the IBindingList or IBindingListView interfaces. This capability can be queried through the SupportsSorting property."
Is this pre-requisite fulfilled in your case?
That documentation also provides a simple sample.
It should be possible for you to adapt your code to make use of the approach demonstrated there, possibly by piping your data through a temporary container of some sort.
My built-in parameter checker demonstrates sorting in a Revit add-in, if I am not mistaken:
I hope this helps.
Best regards,
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
