CAN I CREATE MY OWN OBJECTS WITH CUSTOM PROPERTIES IN REVIT?
I wanna write plugin for Revit that can create custom pipes, ducts, cables with some properties different from Revit's own objects. Can I do it with Revit API 2014?
Best Regards, Nursultan
jeremytammik
Dear Nursultan,
You can add custom properties to the pre-defined Revit BIM elements, e.g. using shared parameters of extensible storage.
For more information, please refer to The Building Coder:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.23
http://thebuildingcoder.typepad.com/blog/storage
http://thebuildingcoder.typepad.com/blog/parameters
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
