Sort Scheduled Elements base on it's Sort/Group Fields to be export in Excel
i'm trying to export the schedule elements to Excel with the same order as it is in Revit Schedule. I retrieved the sorting field of the schedule and try to apply it to elements list with no luck. For now my goal is just to apply one sort/group field and apply multiple sorting condition as i progress. Hope someone can help me.
here is the schedule
here is my code which not working
private IEnumerable<Element> ScheduledElement(Document doc,ViewSchedule view)
				var sort = (from ScheduleSortGroupField i in view.Definition.GetSortGroupFields() select view.Definition.GetField(i.FieldId)).First();
				IEnumerable<Element> elementsOnSchedule = new FilteredElementCollector(doc, view.Id)
					.WhereElementIsNotElementType()
					.OrderBy(c => c.LookupParameter(sort.GetName()));
				return elementsOnSchedule;
Thanks in advance
jeremytammik
Fair59 presents a very comprehensive and well explained solution to Replicate Graphical Column Schedule Sort Order with C# by implementing a custom ColumnMarkComparer class implementing IComparer<FamilyInstance>.
I very strongly expect that you can implement something similar to solve your issue as well.
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi @jeremytammik ,
i have manage to sort using IComparer. however, when field StrorageType is ElementId and String it gives me error. also i wonder how to get value for sorting  if the sort/group field is not accessible in element parameter ( eg. Count, Calculated Field).
here is my code:
private List<Element> ScheduledElement(Document doc,ViewSchedule view)
				List<Element> elementsOnSchedule = new FilteredElementCollector(doc, view.Id)
					.ToElements().ToList();
				if(view.Definition.GetSortGroupFields().Count != 0)
					elementsOnSchedule.Sort(new sortElement(view));
IComparer Class:
public class sortElement : IComparer<Element>
		private ViewSchedule vs {get; set;}
		public sortElement(ViewSchedule view)
			vs = view;
		public int Compare(Element x, Element y)
			var sortField = (from i in vs.Definition.GetSortGroupFields() select i).First();
			var field = vs.Definition.GetField(sortField.FieldId);
			var Param1 = x.LookupParameter(field.GetName());
			var Param2 = y.LookupParameter(field.GetName());
				if (Param1.StorageType == StorageType.Integer)
					return Param1.AsInteger().CompareTo(Param2.AsInteger());
				else if (Param1.StorageType == StorageType.Double)
					return Param1.AsDouble().CompareTo(Param2.AsDouble());
				else if (Param1.StorageType == StorageType.String)
					return Param1.AsString().CompareTo(Param2.AsString());
				else if (Param1.StorageType == StorageType.ElementId)
					return Param1.AsValueString().CompareTo(Param2.AsValueString());
				return 0;
thanks for helping
follow-up on ElementId and string error. i have figured out that i need to use string.compare.
my only issue now is how to get value if the sort field is not accessible from element(eg. count, formula, etc.)
krishna_j64ECZ
Community Visitor
Community Visitor
hi @Anonymous,
Hope below code will resolve your issue for grouping/sorting. You can change parameter value.
SchedulableField schedulableFieldForBaseLevel = def.GetSchedulableFields().FirstOrDefault(
sf => sf.ParameterId == new ElementId(BuiltInParameter.SCHEDULE_BASE_LEVEL_PARAM));
if (schedulableFieldForBaseLevel != null)
baseLevelField = def.AddField(schedulableFieldForBaseLevel);
if (baseLevelField != null)
var sortGroupField = new ScheduleSortGroupField(baseLevelField.FieldId);
sortGroupField.ShowHeader = true;
sortGroupField.SortOrder = ScheduleSortOrder.Ascending;
def.InsertSortGroupField(sortGroupField, 0);
