How to use button event
I used 'In-Place Mass' function!!
uiapp=UIApplication(document.Application)
cmdId=RevitCommandId.LookupPostableCommandId(PostableCommand.InPlaceMass)
UIApplication.PostCommand(uiapp,cmdId)
The results of implementation are as follows.
1)How to push 'Ok' button?
2)How to set the default value to output 'Mass1'?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
To push "OK" you can use the below code
 RevitCommandId Cid=RevitCommandId.LookupPostableCommandId(PostableCommand.InPlaceMass);
                uiapp.PostCommand(Cid);
                uiapp.DialogBoxShowing += new EventHandler<Autodesk.Revit.UI.Events.DialogBoxShowingEventArgs>(DialodBBOX);
 private void DialodBBOX(object sender, DialogBoxShowingEventArgs e)
            e.OverrideResult((int)DialogResult.OK);
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
I used Python to modify and execute the code.  But...not running...
uiapp.DialogBoxShowing(DialogBoxShowingEventArgs.OverrideResult(TaskDialogResult.Ok))
The following error has occurred....
