how to retrieve non rectangular opening
markjvlampad
markjvlampad
Hi to all Expert out there.
is there any chance to retrieve non rectangular opening from wall?
any hint or class to use?
thank you,
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @markjvlampad ,
try using below code
IList<ElementId> eids = wall.FindInserts(true, true, true, true) as IList<ElementId>;
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
jeremytammik
Many different approaches for retrieving all kinds of wall openings have been discussed by The Building Coder, and several have been successfully tested on arbitrary complex shapes:
https://www.google.com/search?q=wall+opening&as_sitesearch=thebuildingcoder.typepad.com
Please let us know what works for you, and what your final solution looks like.
Jeremy Tammik
The Building Coder
