Some model missing when in customer export(IExportContext) Revit models.
As title, I developed an addin application exporting Revit models, and I have implemented the interface IExportContext to export models, but find that in some cases, some small models are missing when in a large scene. And when I export these small models separately, these models can be read and export successfully.  This problem is a low probability issue, but I still want to ask if anybody faced the same issue or can give a advise.
Thanks a lot.
Also, I found that somebody also met the model missing problem, not know if it is the same problem.
https://forums.autodesk.com/t5/revit-architecture-forum/export-to-dwg-small-objects-missing/td-p/738...
jeremytammik
As far as I can tell, the workarounds discussed in the thread that you point to say it all.
Have you tried applying them?
The custom export just exports what is rendered in Revit.
I can imaging that if an object is too small to be seen, it may be omitted. In that case, if you need the export for a non-visual purpose and care about invisible objects, you may have to add some functionality to ensure it is included.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
jeremytammik
I asked the development team about this too, and they say:
Well, the answers in the referred-to thread do not surprise me. IExportContext deals with graphical export, so it is to be expected that small objects might be optimised out.
I think this is by design. There might be different provisions for different types of small objects, but, as a general rule, both print and export can miss them due to how the processing pipeline works. There have been many discussions regarding how this limitation could be removed. A solution will involve a performance penalty and possibly some new UI.
I hope this clarifies.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
