Revit file Working sharing issue among three desktops
Dear support team,
I have three desktops connected to each other using router by LAN cable for data sharing.I have created a central file in one of the system and shared the same to other two systems but problem i have encountered here is create new local option in revit opening tab in turned to grey while we select the file when trying open the file.
Please note that we don't have server in those systems.
Awaiting for your reply.
Maniteja Sundara
jeremytammik
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
