Solid by union of solids in list
hzamani
hzamani
I'm making a recursive function to create a solid which is the union of all solids that are given. Here's my code:
        private static Solid SolidByUnion(List<Solid> solids)
            Solid result;
            if (solids.Count > 2)
                List<Solid> restOfSolids = solids.Skip(0).Take(solids.Count - 1).ToList();
                Solid solid1 = solids[0];
                Solid solid2 = SolidByUnion(restOfSolids);
                result = BooleanOperationsUtils.ExecuteBooleanOperation(solid1, solid2, BooleanOperationsType.Union);
                return result;
            else
                Solid solid2 = solids[1];
                return result;
However what I'm getting as the result is only the union of first two ( or maybe last two ) solids in the list. It's probably a basic recursion mistake but I can't figure out what I'm doing wrong here. Any hints?
Thanks.
jeremytammik
Normally, iteration is easier to implement and understand than recursion.
Here is an iterative solution:
http://thebuildingcoder.typepad.com/blog/2013/04/room-and-furniture-loops-using-symbols.html#6
    Solid union = null;
    foreach( GeometryObject obj in geo )
      Solid solid = obj as Solid;
      if( null != solid
        && 0 < solid.Faces.Size )
          if( null == union )
            union = solid;
          else
            union = BooleanOperationsUtils
              .ExecuteBooleanOperation( union, solid,
                BooleanOperationsType.Union );
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
hzamani
Thanks Jeremy,
Your solution solves my problem.
Cheers.
PS: I'm still looking however to the recursive solution ( just for learning purposes ) if anyone has any ideas.
FAIR59
you misunderstand the use of List<>.Skip(). The value passed to the function is the number of elements to skip, and  not the index of the listelement to needs to be skipped.
So in solids.Skip(0).Take(solids.Count - 1).ToList();  the skip part doesn't do anything. The Take part then selects the first Count-1 entries. You never process the last entry.
Correct code syntax to eliminate the first entry:
			solids.GetRange(1,solids.Count-1);
			solids.Skip(1);
hzamani
Thank you! I was so focused on the recursion itself, never suspected this part.
Cheers.
