Can I create a ParameterSet using multiple parameters obtained w/GetParameters?
rita.aguiar
rita.aguiar
I would like to create a List<string> with several strings corresponding to different parameter names of an element.
The elements in my Revit model have a few parameters (created with the Autodesk Classification Manager for Revit), which I would like to get, and add to the List<string> paramNames.
(Attached .png also shows the code)
List<string> paramNames = new List<string>();
foreach (Element e in elementSet)
    ParameterSet parameters = e.GetParameters("Classification.Uniclass.Ss.Number",
                                              "Classification.Uniclass.EF.Number",
                                              "Classification.Uniclass.Ss.Description",
                                              "Classification.Uniclass.Pr.Number",
                                              "Classification.Uniclass.Pr.Description");
//GetParameters only takes one argument so I can't do it like I have been trying //How can I get more than one parameter to create a ParameterSet? foreach (Parameter parameter in parameters) { name = parameter.Definition.Name; if (!paramNames.Contains(name)) { paramNames.Add(name); } } } paramNames.Sort();
Any help would be appretiated!
naveen.kumar.t
Autodesk Support
Autodesk Support
hi @rita.aguiar,
can you try using the below code
List<string> para_names = new List<string>();
IList<Element> elements;
                foreach(Element e in elements)
                    foreach(Parameter p in e.Parameters)
                        string para_name = p.Definition.Name;
                        if(para_name!=null)
                            if(!para_names.Contains(para_name))
                                para_names.Add(para_name);
                para_names.Sort();
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
rita.aguiar
Thank you @naveen.kumar.t
If I understood correctly, your code will get all parameters of an element using e.Parameters.
However, I would like to only get a few (the 5 paramater named "Classification.Uniclass.Ss.Number", "Classification.Uniclass.EF.Number", "Classification.Uniclass.Ss.Description", "Classification.Uniclass.Pr.Number", and "Classification.Uniclass.Pr.Description").
On a side note, the variable 'elements' is local so I get an error saying that "it cannot be declared in this scope because it is used in an enclosed local scope to define a local or parameter".
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @rita.aguiar,
are you looking for this?????
List<string> final_parameter_name_list = new List<string>();
                List<string> Interested_Parameter_names = new List<string>();
                Interested_Parameter_names.Add("Classification.Uniclass.Ss.Number");
                Interested_Parameter_names.Add("Classification.Uniclass.EF.Number");
                Interested_Parameter_names.Add("Classification.Uniclass.Ss.Description");
                Interested_Parameter_names.Add("Classification.Uniclass.Pr.Number");
                Interested_Parameter_names.Add("Classification.Uniclass.Pr.Description");
                IList<ElementId> eids = sf.GetElementIds() as IList<ElementId>;
                foreach(ElementId eid in eids)
                    Element e = doc.GetElement(eid);
                        if(Interested_Parameter_names.Contains(p.Definition.Name))
                            if(!final_parameter_name_list.Contains(p.Definition.Name))
                                final_parameter_name_list.Add(p.Definition.Name);
final_parameter_list contains list of parameters but here in the list , parameter names are not repeated.
Naveen Kumar T
