Retrive mesh of area element
I'm trying to triangulate an area element and then turn it into an svg object.
It's possible? Does anyone know a method to do it?
Thank you.
Sorry for my English.
jeremytammik
First of all, explore the area element and its geometry using RevitLookup and see what you can find.
I would probably start by retrieving its boundary segments and use those to construct the SVG:
https://apidocs.co/apps/revit/2019/8e0919af-6172-9d16-26d2-268e42f7e936.htm
http://thebuildingcoder.typepad.com/blog/2009/04/area-boundary-segments.html
By the way, my RoomEditorApp retrieves and exports room surfaces to SVG, so that might be of interest as well:
https://github.com/jeremytammik/RoomEditorApp
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks Jeremy,
sorry if I answer you only now but I have been busy in other jobs.
I have found your suggestions very useful with which they are able to recover the vertices of the area, but now we have decided to abandon SVG for a WebGL viewer that requires the triangulation of the area. Do you know if there is a method in the API? Can you give me an example?
Cheers
jeremytammik
Every single geometrical object provided by the Revit API can be easily triangulated using the Triangulate method:
https://apidocs.co/apps/revit/2019/8cd4a132-b874-442d-6739-43df3319eac9.htm
Analogously, curves provide a Tessellate method:
https://apidocs.co/apps/revit/2019/f95f3199-3251-c708-c5a3-a0e9ef95ecfa.htm
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
