snoop db : Snoop selection with an array of strings
ivo.lafeber
ivo.lafeber
I have an extensible storage with an array of strings, the array is used to add some unique id’s of other element’s to an element.
I can write / read the data, but snoop db gives a list of char’s instead of one string, is this a flaw in my software, or is it a strange way of showing the data in snoop db.
Dim KabelIdList As New List(Of String)
KabelIdList.Add(“test”)
Kabel_Entity.[Set](Of IList(Of String))("Unieque_ElementId", KabelIdList)
jeremy_tammik
Yes, that seems a bit suboptimal.
Have you tried out what it looks like in the new and vastly improved RevitLookup 2024?
https://thebuildingcoder.typepad.com/blog/2023/04/revit-2024-and-revitlookup-2024.html
The new version can also be used in an older release of Revit.
Anyway, I asked Nice3point for you whether he can explain:
https://github.com/jeremytammik/RevitLookup/issues/156
nice3point
Use the latest version of RevitLookup if possible, it is available for Revit versions 21-24
This issue has already fixed
https://github.com/jeremytammik/RevitLookup/releases/latest
Rui_Tang-Symetri_USA
Hi @jeremy_tammik , unfortunately this is still an issue in the new RevitLookup. It is VERY slow to open this window.
This is how I got to the field:
jeremy_tammik
Thank you for raising this as an issue in the RevitLookup GitHub repository:
