Simplify elements geometry
skabart1993
skabart1993
Hello everyone,
I am trying to simfplify the geometry of elements (such as cylinders, shperes, etc.) throgh the API.
My first idea was simple:
1. Retrieve a mesh from all faces with low quality using face.Triangulate(0);
2. Apply the new mesh for element's geometry.
However, it does not work. I have seen messages on the forum stating that working with geometry through the API is not allowed. Anyway, I believe that there it should be another approach to tackle this issue. I would appreciate any help.
jeremy_tammik
No. There is no way that you can specify Revit element geometry. Please bear in mind that Revit is a BIM authoring tool. The BIM is completely driven by parameters and constraints.
There is no geometry in the BIM!
The model as you see it (and its geometry) is just a view of the elements, their relationships, parameters and constraints.
jeremy_tammik
Edited and added to the blog for the sake of completeness:
https://thebuildingcoder.typepad.com/blog/2023/10/no-geometry-touching-geometry-and-cut-geometry.htm...
