Shared Parameter : Set default value
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created un shared parameter on a type with API, but I don't found how set the parameter with a default value.
This is my code :
using (Transaction transaction = new Transaction(doc, "Some operations"))
transaction.Start();
ElementType duplicate = type.Duplicate("Test - " + type.Name);
// Récupération des paramètres partagées
GlobalApp.Instance.CreateSharedFile();
this._application.Application.SharedParametersFilename = GlobalApp.Instance.CurrentDocumentRoot + "-PIMSharedParameters.txt";
DefinitionFile file = this._application.Application.OpenSharedParameterFile();
if (file == null)
return;
DefinitionGroup group = file.Groups.get_Item("MyGroup");
if (group == null)
group = file.Groups.Create("MyGroup");
Definition def;
if (group.Definitions.Contains(group.Definitions.get_Item("My Param")))
def = group.Definitions.get_Item("My Param");
else
ExternalDefinitionCreationOptions options = new ExternalDefinitionCreationOptions("My Param", ParameterType.Text);
options.Visible = true;
options.HideWhenNoValue = false;
options.UserModifiable = true;
def = group.Definitions.Create(options);
BuiltInCategory builtInCategory = (BuiltInCategory)Enum.ToObject(typeof(BuiltInCategory), duplicate.Category.Id.IntegerValue);
CategorySet cats = this._application.Application.Create.NewCategorySet();
cats.Insert(doc.Settings.Categories.get_Item(builtInCategory));
TypeBinding bind = this._application.Application.Create.NewTypeBinding(cats);
bool result = doc.ParameterBindings.Insert(def, bind, BuiltInParameterGroup.PG_DATA);
// Default value
transaction.Commit();
Can someone help me ?
Thnaks.
