Multi-targeting Revit 2019 + 2020 using MSBuild
JOfford_13
JOfford_13
I'm trying to use msbuild to create a multi-target project per the example below however I can't seem to get it to work with Revit 2019 and 2020 because they share the same .NET framework (4.7).  Does anyone have a quick fix to handle these two versions of Revit?  I haven't seen any articles that use msbuild to build multiple versions of the same framework.  Are there any big problems if I target 4.7.2 for Revit 2020?
https://thebuildingcoder.typepad.com/blog/2018/06/multi-targeting-revit-versions-cad-terms-texture-m...
kraftwerk15
I build against multiple frameworks without issues.
JOfford_13
Agreed setting 2020 to build against 4.7.1 or 4.7.2 works but wanted to confirm this is best course of action.  I always thought the Revit API wanted the .NET frameworks to match explicitly.
joshua.lumley
I'v'e been using 4.7.2 since it was released and never had an issue.
