Shared Parameter : Set default value
nicolas.calvi
nicolas.calvi
I have created un shared parameter on a type with API, but I don't found how set the parameter with a default value.
This is my code :
using (Transaction transaction = new Transaction(doc, "Some operations"))
	transaction.Start();
	ElementType duplicate = type.Duplicate("Test - " + type.Name);
	// Récupération des paramètres partagées
	GlobalApp.Instance.CreateSharedFile();
	this._application.Application.SharedParametersFilename = GlobalApp.Instance.CurrentDocumentRoot + "-PIMSharedParameters.txt";
	DefinitionFile file = this._application.Application.OpenSharedParameterFile();
	if (file == null)
		return;
	DefinitionGroup group = file.Groups.get_Item("MyGroup");
	if (group == null)
		group = file.Groups.Create("MyGroup");
	Definition def;
	if (group.Definitions.Contains(group.Definitions.get_Item("My Param")))
		def = group.Definitions.get_Item("My Param");
	else
		ExternalDefinitionCreationOptions options = new ExternalDefinitionCreationOptions("My Param", ParameterType.Text);
		options.Visible = true;
		options.HideWhenNoValue = false;
		options.UserModifiable = true;
		def = group.Definitions.Create(options);
	BuiltInCategory builtInCategory = (BuiltInCategory)Enum.ToObject(typeof(BuiltInCategory), duplicate.Category.Id.IntegerValue);
	CategorySet cats = this._application.Application.Create.NewCategorySet();
	cats.Insert(doc.Settings.Categories.get_Item(builtInCategory));
	TypeBinding bind = this._application.Application.Create.NewTypeBinding(cats);
	bool result = doc.ParameterBindings.Insert(def, bind, BuiltInParameterGroup.PG_DATA);
	// Default value
	transaction.Commit();
Can someone help me ?
Thnaks.
lukaskohout
Since you cannot do this in UI manually you cannot do this with API.
You have to get all the elements with that parameter assigned and set the value directly to them.
Hitting Accepted Answer is a Community Contribution from me as well as from you.
Revitalizer
which means that he needs to implement an IUpdater to intercept newly created elements, setting the default value.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
