Setting the "Title on Sheet" parameter of a view
J33C316
J33C316
How do I set the "Title on Sheet" parameter of a view? It's not a BuiltInParameter like I expected.
This post no longer works either. Thanks for your help.
https://forums.autodesk.com/t5/revit-api-forum/how-to-set-quot-title-on-sheet-quot-property-for-a-dr...
so-chong
You could try to use the LookupParameter Method to get the "Title on Sheet" parameter of a view.
Something like this
view.LookupParameter("Title on Sheet")
J33C316
Thanks but I’m trying to set it not get it. I know it’s blank currently.
joshua.lumley
Easy, title on sheet is in fact the VIEW_DESCRIPTION BIP.
 uidoc.ActiveView.get_Parameter(BuiltInParameter.VIEW_DESCRIPTION).Set("Hello World");
so-chong
Well It all depends what you want to set as "Title on Sheet" value.
So if you want to set the view name you can do something like this
view.LookupParameter("Title on Sheet").Set(view.Name);
You can use String methods like Substring or Replace to change your view name.
 https://docs.microsoft.com/en-us/dotnet/api/system.string.substring?view=netcore-3.1
