Setting Active Workset by using Name
62BJW
62BJW
I've seen examples of setting the Active Workset by getting the ID of an element but I want to set the active workset by selecting a name in a dialog box. I already have a dialog box with a ListBox on it that populates a list of worksets in the file.
I see there'a a Workset.Create method but no Workset.Set method.
Thanks.
JimJia
hi Bernie,
You can check desired workset via the name and then use the worksetid of disired workset, it's OK for you?
WorksetId activeId;
if(workset.Name == "<workset_name>")
     activeId = workset.Id;
Document.GetWorksetTable().SetActiveWorksetId worksetId);
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
62BJW
Thanks for the reply JimJia. I've been busy on other things. Will try your suggestion soon. Thanks again!
jeremytammik
Dear Bernie,
Analogously to #14926114 [Displaying Workset dialog on Open], the automatically generated DAS ticket #14927695 [Setting Active Workset by using Name] has been reopened, saying, Customer never received any workable solution... Will assign to queue.
Are you still in need of help in this issue? If so, then please say so and let us continue discussing it here in the public thread.
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Autodesk Developer Network, ADN Open
The Building Coder
