Load application
Load application
Load application
Hi.
Is it possible to load an application when a file opens instead of when Revit starts?
This application is load even in  *.rfa files and there is no use for that.
Thank you
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
Could you please explain in detail on what you are trying to achieve?
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Revitalizer
see
UIAppliation.LoadAddIn and
UIControlledApplication.LoadAddin
in RevitAPI.chm
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Revitalizer
your AddIn can easily check if the current document is a family document (doc.IsFamilyDocument).
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
What I need is to change de visibility of the ribbon panels from my App  when active document changes. That way I'll be able to check the active document type and turn on and off the visibility of my ribbon panels.
Revitalizer
you need to set PushButtonData.AvailabilityClassName
https://forums.autodesk.com/t5/revit-api-forum/hide-ribbon-tab-if-family-document-active/m-p/8275558
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
