Setting 3Dview to topview and North upwards
Hi
I have genereted some 3D views and set the target, eye and forward
But I need to set the view with north upwards, I think I have to set the Right Direction, but I can't get to that parameter !
Regards Anders
Hi
The creation of the 3D view itself is OK, but they are all titled 90° to the right
Eye and up are located in the midtel og the section box and that workes fine allso the level of the target and eye of the camera
My code to create the 3D view look like this:
View3D view = View3D.CreatePerspective(mainDocument, viewFamilyType.Id);
XYZ eye = new XYZ((SecBMin.X + SecBMax.X) / 2, (SecBMin.Y + SecBMax.Y) / 2, 1);
XYZ up = new XYZ((SecBMin.X + SecBMax.X) / 2, (SecBMin.Y + SecBMax.Y) / 2, 0);
XYZ forward = new XYZ(0, 0, 1);
view.SetOrientation(new ViewOrientation3D(eye, up, forward));
Parameter EYE_ELE = view.get_Parameter(BuiltInParameter.VIEWER_EYE_ELEVATION);
EYE_ELE.Set(Alevel.Elevation + 78.75);
Parameter Tar_ele = view.get_Parameter(BuiltInParameter.VIEWER_TARGET_ELEVATION);
Tar_ele.Set(Alevel.Elevation + 49);
Hope someone can guide me 🙂
Regards
Anders
jeremytammik
Dear Anders,
Thank you for your query.
First I took a quick look at the Revit 2016 view API enhancements to see whether there is anything useful in there:
View3D additions
http://thebuildingcoder.typepad.com/blog/2015/04/whats-new-in-the-revit-2016-api.html#5.10
I saw nothing relevant, however.
Then I checked and confirmed that the View.RightDirection and View.UpDirection properties are both read-only.
Then I went back to the beginning and looked at your sample code snippet, where I should have started to begin with.
How about changing the up direction of your ViewOrientation3D?
As far as I can tell, you are setting it to a very strange value:
Note that the variable that you call 'eye' here is the eye position, which is a point.
The up and forward directions are vectors.
Therefore, it is really pretty weird to define 'up' to have the same X and Y coordintates as 'eye'.
How about trying something like this:
XYZ up = XYZ.BasisY;
XYZ forward = XYZ.BasisZ;
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Hi
After a while I have stared on the automatic 3D views creation again, but still with no luck.
The North direction is still wrong.
When I use the eye, Up, Forward settings as below, North is turning Right insted of up
XYZ eye = new XYZ((SecBMin.X + SecBMax.X) / 2, (SecBMin.Y + SecBMax.Y) / 2, 1); // in the middle of the section box
If I swap the Up and Forward Z/Y:
XYZ up = XYZ.BasisZ;
XYZ forward = XYZ.BasisY;
Now I got the direction right, but the eye target is not placed in the midtel af the outer walls don't seem prarallel.
What do I do wrong ?
Isn't it possible to create a 3D perspective facing North ?
If not, is it possible to rotate the view after creation ?
Best Regards
Anders
jeremytammik
Dear Anders,
Thank you for your update.
I do not know off-hand what might be wrong.
Yes, of course you can create a 3D perspective facing north.
Yes, you can probably rotate the view after creation as well.
Maybe back to basics would be best.
Do you understand the difference between points and vectors that I referred to in a previous answer?
Have you looked at the description of the views in the developer guide?
Maybe some study would do you good? 🙂
Welcome to Revit 2016 Learning
http://help.autodesk.com/view/RVT/2016/ENU
Revit API Developers Guide
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-F0A122E0-E556-4D0D-9D0F-7E72A9315A42
Basic Interaction with Revit Elements
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-54D8EFF1-5274-43D8-BD0C-68209F36BBD2
Views
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-A7CE4D5C-8839-4CD8-817F-BE8B17F91D97
View3D
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-A7FA8DBC-830E-482D-9B66-147399524442
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
