How obtain updated Parameter Value within a public void?
Hi,everyone
I have parameter A, parameter B, and Parameter C of a element
first I need to set parameter A or B to value (Yes) or (No) as it needs.
and use the new parameter value to do  the following if statements to set Parameter C.
But somehow I can never obtain the updated parameter.
If parameter A value was set to "No" when I select the element. The value will states the same even after I set to "Yes" and get the parameter again.
Is there anyway to update the parameter value of and selected element within the code?
 Parameter pA = e.get_Parameter("A");
Parameter pB = e.get_Parameter("B");
Parameter pC = e.get_Parameter("C");
pA.Set(0);
pb.Set(0);
Parameter npA = e.get_Parameter("A");
Parameter npB = e.get_Parameter("A");
string ParaA = npA.AsValueString();
If(npA == "Yes" || npB == " Yes")
ParaC.Set(1);
If(npA == "No" && npB == " No")
pC.Set(0);
ollikat
Hi
Have you tried using the Document.Regenerate() after setting the parameters? It indeed might need that.
You can find some related topics from the Building coder site i.e. http://thebuildingcoder.typepad.com/blog/2010/06/to-regenerate-or-not-to-regenerate.html
Also there's something related in this forum also:
http://forums.autodesk.com/t5/revit-api/document-modification-transactions-parameters-etc/m-p/545850...
Hope this helps.
Revitalizer
you are comparing a Parameter object with a string.
You need to compare the Parameter's value.
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
This method works great
I also found another example from Jeremy:
http://thebuildingcoder.typepad.com/blog/regen/
Hi,Revitalizer
Thanks for your reply.
The new code should be:
doc.Regenerate();
//Convert Parameter to Value String
string ParaB = npB.ASValueString();
If( ParaA == "Yes" || ParaB == "Yes")
ParaC.Set(1);
If( ParaA == "No" && ParaB == "No")
pC.Set(0);
