set Schedule Filter
set Schedule Filter
Ryan
set Schedule Filter
Ryan
I've duplicated a schedule with come code, but now i would like to change a filter in the schedule that filters by a shared parameter. IE shared parameter "Unit #" equals "//user input"
Ive search up and down the REVITSDK schedule creation sample. But, i cant figure it out from there.
Thanks!
		public void UnitCopy()
       Document doc = this.ActiveUIDocument.Document;
            // Filter views that match the required criteria
            FilteredElementCollector collector
              = new FilteredElementCollector(doc)
                .OfClass(typeof(ViewSchedule));
            // Get the specific view(s)
            IEnumerable<ViewSchedule> views
              = from Autodesk.Revit.DB.ViewSchedule f
                in collector
                where (f.ViewType == ViewType.Schedule
                  && f.ViewName.Equals("Unit Default"))
                select f;
            using (Transaction trans = new Transaction(doc, "ViewDuplicate"))
                trans.Start();
                foreach (ViewSchedule vw in views)
                    // Duplicate the existing ViewPlan view
                    ViewSchedule newView = doc.GetElement(vw.Duplicate(ViewDuplicateOption.Duplicate)) as ViewSchedule;
                    // Assign the desired name
                    if (null != newView)
                        newView.ViewName = "MyViewName";//to be user input later.
// this is just my attempt.
                    string sfield = "Unit #";
                    ScheduleField unit = newView.Definition.GetField(fieldId);
                    if (unit.ParameterId == new ElementId(BuiltInParameter.SCHEDULE_FIELDS_PARAM))
       ScheduleFilter filter = new ScheduleFilter(unit.FieldId, ScheduleFilterType.Equal, sfield);
       newView.Definition.AddFilter(filter);
Aaron.Lu
Can you let us know what is the problem of your code? thanks.
Aaron Lu
Developer Technical Services
Autodesk Developer Network
public static void AddFilterToSchedule(Document doc, ViewSchedule schedule)
            string field = "Wood - Stud Layer";
            string filterby = "MATERIAL_NAME";
            string filterType = "Equal";
            BuiltInParameter filterByParameter = (BuiltInParameter)Enum.Parse(typeof(BuiltInParameter), filterby);
            ScheduleFilterType scheduleFilterType = (ScheduleFilterType)Enum.Parse(typeof(ScheduleFilterType), filterType);
            using (Transaction transaction = new Transaction(doc, "Filter Schedule"))
                transaction.Start();
                if (schedule.Name == "wall-material-takeoff")
                    ScheduleDefinition definition = schedule.Definition;
                    ScheduleField scheduleField = FindField(viewSchedule, filterByParameter);
                    // If field not present, add it
                    if (scheduleField == null)
                        scheduleField = definition.AddField(ScheduleFieldType.Instance, new ElementId(filterByParameter));
                    //scheduleField.IsHidden = false;
                    ScheduleFilter filter = new ScheduleFilter(scheduleField.FieldId, scheduleFilterType, field);
                    definition.AddFilter(filter);
                transaction.Commit();
