Convert Revit Macro to Revit API
desdinova
desdinova
I am trying to convert this macro to revit api but i get "Expected class, delegate, enum, interface, or struct" error.
How can i solve this problem?
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
namespace Walls
public class WallPickFilter : ISelectionFilter
public bool AllowElement(Element e)
return (e.Category.Id.IntegerValue.Equals(
(int)BuiltInCategory.OST_Walls));
public bool AllowReference(Reference r, XYZ p)
return false;
public void WallJoinsMiterByPick()
UIDocument uidoc = this.ActiveUIDocument;
Document doc = uidoc.Document;
ISelectionFilter wallfilter=new WallPickFilter();
IList<Reference> refList = new List<Reference>();
try
// create a loop to repeatedly prompt the user to select a wall
while (true)
refList.Add(uidoc.Selection.PickObject(ObjectType. Element,wallfilter,
"Select elements in order to change join type to miter. ESC when finished."));
// When the user hits ESC Revit will throw an OperationCanceledException which will get them out of the while loop
catch
using(Transaction t = new Transaction(doc, "Wall joins to Miter"))
t.Start();
foreach (Reference r in refList)
Element wall1= doc.GetElement(r);
LocationCurve wCurve = wall1.Location as LocationCurve;
wCurve.set_JoinType(0,JoinType.Miter);
wCurve.set_JoinType(1,JoinType.Miter);
doc.Regenerate();
t.Commit();
jeremytammik
Dear Desdinova,
I would suggest that you work through the standard Revit API getting started material first to understand the architecture and installation of a normal Revit add-in, how it is installed and loaded by Revit on startup:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
The easiest way to do that is to work throught the My First Revit plugin and DevTV tutorials provided in the Revit Developer Centre:
http://www.autodesk.com/developrevit
Then all will become clear and easy.
Good luck and have fun!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hello desdinova,
if I understand you correctly, you want to convert your macro into an external command. You need to implement an interface called IExternalCommand, and call an Execute method. Something like this :
namespace Walls
[Transaction(TransactionMode.Manual)] [RegenerationAttribute(RegenerationOption.Manual)] public class Command: IExternalCommand { UIDocument uidoc
Document _doc;
public Result Execute( ExternalCommandData commandData, ref string message, ElementSet elements) { UIApplication rvtUIApp = commandData.Application; uiDoc = rvtUIApp.ActiveUIDocument; doc = uiDoc.Document; WallJoinsMiterByPick()
return Result.Succeeded; }
And remove this part from your WallJoinMiterByPick()-method.
But like Jeremy said, check out My first Revit plugin and all labs that are available, then this will be much easier. No prior programming experince needed 🙂
Good luck!
/Martin
desdinova
Thank you for your answers
What is wrong in this code
i get
Walls_Miter.Command.Execute(Autodesk.Revit.UI.ExternalCommandData, ref string, Autodesk.Revit.DB.ElementSet)': not all code paths return a value
Since 'Walls_Miter.Command.WallJoinsMiterByPick()' returns void, a return keyword must not be followed by an object expression
error
namespace Walls_Miter
public class Command : IExternalCommand
UIDocument uidoc;
Document doc;
ref string message,
uidoc = rvtUIApp.ActiveUIDocument;
return false;
try
while (true)
refList.Add(uidoc.Selection.PickObject(ObjectType.Element,wallfilter,
catch
t.Start();
doc.Regenerate();
t.Commit();
your execute method isn't returning a result:
Move this into the execute method.
But right now it's not doing anything, you also have to call WallJoinsMiterByPick() inside the execute method.
.......ActiveUIDocument;
WallJoinsMiterByPick();
And when posting code please use the insert code button to make the code more readable.
good luck
desdinova
Dear Maer6427,
Thanks for reply
It worked...
