Set material parameter value
Yonas89
Yonas89
Hello, I am wondering how I could set any material  value programmatically to material parameter  as in this image below? What's the way to iterate through the materials and assign its  value to the parameter?
Yonas89
if anyone face similar problem, I was able to solve this with following snippet:
 public void SetMaterial(FamilySymbol fs)
               IList<Parameter> pars = fs.GetOrderedParameters();
                foreach (Parameter p in pars)
                    if (p.Definition.Name == "Material")
                        Material m = GetMaterial(doc, "Glass");
                        if (m!= null)
                            fs.Category.Material = m;
                            p.Set(m.Id);
 public Material GetMaterial (Document doc, string matName)
            FilteredElementCollector collector = new FilteredElementCollector(doc);
            Material mat = null;
            var materials = collector.WherePasses(new ElementClassFilter(typeof(Material))).Cast<Material>();
            foreach(Material m in materials)
                if (m.Name == matName)
                    mat = m;
                    break;
            return mat;
jeremytammik
Dear Yonas,
Thank you for your query and solution.
Here is an untested optimised version of your second method:
    return new FilteredElementCollector(doc)
      .OfClass( typeof(Material)))
      .Cast<Material>()
      .Where( m => m.Name == matName );
To improve the first, the most important thing to do is determine the built-in parameter enumeration value corresponding to the "Material" parameter.
If you don't have it at hand, use RevitLookup to find out.
Let's assume it is ELEMENT_MATERIAL.
Then you can access the parameter directly using the built-in enum instead of retrieving and iterating over all the element parameters.
If you insist on using the name, you can use LookupParameter, if you are sure that there is only one matching that name, or GetParameters taking a string, to retrieve all with a given name.
    Parameter p = fs.GetParameter( BuiltInParameter.ELEMENT_MATERIAL );
    if (null != p )
      if (m!= null)
        p.Set(m.Id);
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Yonas89
@jeremytammik,
thanks a lot!
amro14181998
Observer
Observer
sir I can't find this parameter name ELEMENT_MATERIAL   what is it now in revit 2023 call?
