Detet keyboard input
stever66
Advisor Advisor
stever66
Is it possible to detect text input from the keyboard?  I don't see any revit specific commands related to getting keyboard input, so I'm hoping this is possible with general Windows C# routines.
The problem is, most general Windows examples showing key press events assume there is a form being displayed, and the code examples are tied to the form.  I don't want to add a form, I just want to detect key presses from within the revit window so I can expand on the Keyboard Shortcuts Revit includes.
Steve
stever66
Any ideas on this?
does anyone think it's possible or not possible?
it really seems like revit would have an event handler for keyboard input.
FAIR59
I don't think Revit has any Event for keyboard input. You could define your own Listener like this:
class Listener : System.Windows.Forms.NativeWindow
            public Listener(IntPtr hWnd)
                // assign the handle and listen to this control's WndProc
                this.AssignHandle(hWnd);
            protected override void WndProc(ref Message m)
                // listen to WndProc here, do things
//                StringBuilder.AppendLine(string.Format("<{0}>,  {1}", m.Msg, m.ToString()));
                base.WndProc(ref m);
//      Process process = Process.GetCurrentProcess();
//      Listener intercept = new Listener(process.MainWindowHandle));
jeremytammik
I do not believe that you need a form to detect a key press.
I searched the internet for '.net detect key press' and found:
https://duckduckgo.com/?q=.net+detect+key+press
https://stackoverflow.com/questions/1100285/how-to-detect-the-currently-pressed-key
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
