Set material parameter programmatically.
mohd.fadel
mohd.fadel
I'm trying to set the custom parameter of a material programmatically. This is my code so far:
foreach (ElementId materialId in f.GetMaterialIds(false))
                Material material = f.Document.GetElement(materialId) as Material;
                Element el = doc.GetElement(elemId);
                ParameterSet parameters = el.Parameters;
                foreach (Parameter param in parameters)
                    if (param.Definition.Name == "USER_DEFINED_FIELD")
                        switch (param.StorageType)
                            case Autodesk.Revit.DB.StorageType.String:
                                if (String.IsNullOrWhiteSpace(param.AsString()))
                                        param.Set("Hello");
                                        param.SetValueString("Hello");
                                break;
                            default:
                                break;
Furthermore, I have this code wrapped in a transaction. However, nothing is happening. Any ideas?
Any help is appreciated.
M.Fadel
mohd.fadel
Sorry correction,
The
 line is for when i tried implementing Jeremy's post [http://thebuildingcoder.typepad.com/blog/2013/01/read-material-asset-parameter.html]
However, i didn't know what to do here:
PropertySetElement property = doc.GetElement(
    material.StructuralAssetId ) as PropertySetElement;
  Parameter paramTensionParallel
    = property.get_Parameter( BuiltInParameter
      .PHY_MATERIAL_PARAM_TENSION_PARALLEL );
Is the first method not valid (without the initialization of a Material variable)?
M.Fadel
mohd.fadel
Update:
I was able to figure out the issue. It was:
that was causing the issue.
I just used a regular FilteredElementCollector instead of a FamilyInstanceCollector and iterated through that collection's elements.
Thank you.
M.Fadel
