Disable the error highlighted elements are joined but do not intersect
When I want to join wall and structural framing it shows error that highlighted elements are joined but do not intersect. What this error mean?
And if I want to disable this error and create own taskdialog box and display my error how I do this?
this is my code:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
namespace JoinGeometry
[Transaction(TransactionMode.Manual)]
class WBjoin
bool check;
public Result Execute(ExternalCommandData commandData)
UIApplication uiApp = commandData.Application;
// UIDocument uiDoc = uiApp.ActiveUIDocument;
// Application app = uiApp.Application;
// Document doc = uiDoc.Document;
UIDocument uidoc = uiApp.ActiveUIDocument;
Document doc = uidoc.Document;
//--get walls on the active view-----------
FilteredElementCollector collWalls = new FilteredElementCollector(doc, doc.ActiveView.Id);
collWalls.OfClass(typeof(Wall));
foreach (Wall w in collWalls)
FilteredElementCollector wallbeam = new FilteredElementCollector(doc, doc.ActiveView.Id);
wallbeam.OfClass(typeof(FamilyInstance));
wallbeam.OfCategory(BuiltInCategory.OST_StructuralFraming);
BoundingBoxXYZ bb = w.get_BoundingBox(doc.ActiveView);
Outline outline = new Outline(bb.Min, bb.Max);
BoundingBoxIntersectsFilter bbfilter =
new BoundingBoxIntersectsFilter(outline);
wallbeam.WherePasses(bbfilter);
foreach (FamilyInstance bem in wallbeam)
using (Transaction t = new Transaction(doc, "Join All Walls/beam"))
t.Start();
try
check = JoinGeometryUtils.AreElementsJoined(doc, w, bem);
if (check == true)
else
JoinGeometryUtils.JoinGeometry(doc, w, bem);
catch
TaskDialog.Show("revit", "cannot joined");
t.Commit();
return Result.Succeeded;
I want to join wall and column but there is problem in join. The two element bounding box is joined but not the actual elements are interesect,if I join that element is shows error. I want make code such a way that it check bounding box and also check the actual element is intersect or not. If both condion is statisfy then it join the element.How I do this?
I using the previous posted code.
Mustafa.Salaheldin
Please try the following code and tell me if it satisfies your needs:
using System;
using System.Linq;
using System.Text;
    class WBjoin
        bool check;
                BoundingBoxIntersectsFilter bbfilter = new BoundingBoxIntersectsFilter(outline);
                        t.Start();
                        FailureHandlingOptions options = t.GetFailureHandlingOptions();
                        WarningDiscard preproccessor = new WarningDiscard();
                        options.SetFailuresPreprocessor(preproccessor);
                        t.SetFailureHandlingOptions(options);
                        try
                            if (check == true)
                            else
                        catch
                        t.Commit();
        public class WarningDiscard : IFailuresPreprocessor
            FailureProcessingResult
              IFailuresPreprocessor.PreprocessFailures(FailuresAccessor failuresAccessor)
                String transactionName = failuresAccessor.GetTransactionName();
                IList<FailureMessageAccessor> fmas = failuresAccessor.GetFailureMessages();
                if (fmas.Count == 0)
                    return FailureProcessingResult.Continue;
                bool isResolved = false;
                foreach (FailureMessageAccessor fma in fmas)
                    if (fma.HasResolutions())
                        failuresAccessor.ResolveFailure(fma);
                        isResolved = true;
                if (isResolved)
                    return FailureProcessingResult.ProceedWithCommit;
If it is what you want please mark this reply as an answer.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
