Offset Value refresh issue revit document through Revit API
Hi All,
I am trying to set offset in my C# code through Revit API. Problem is that, after transaction commited offset value does not change in my revit doc.
could you please help me out.
Hi All,
Please find attached screencast, what exactly i am looking for.
Please suggest any idea.
In my experience, This kind of problem is usually solved by performing a Document.Regenerate() before setting the offset parameter.
Hi Scott_Wilson,
Thank you for your reply.
I have tried the same, also tried doc.refresh(), still failing same.
Please help me.
