SELECTING ELEMENTS CUT BY ACTIVE VIEW PLANE RETURNS NOTHING
AGYEMANG.OFOSU
AGYEMANG.OFOSU
I have an issue selecting beams that are cut by the view plane. Unfortunately the code returns nothing.
public void Show()
			UIDocument uidoc = this.ActiveUIDocument;
			Document doc = uidoc.Document;
			BoundingBoxXYZ box = doc.ActiveView.CropBox;
			Outline outline = new Outline(box.Min, box.Max);
			BoundingBoxIntersectsFilter beamintersect = new BoundingBoxIntersectsFilter(outline);
			List<Element> beams = new FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_StructuralFraming).WherePasses(beamintersect).WhereElementIsNotElementType().ToElements().ToList();
			ICollection<ElementId> idc = new List<ElementId>();
			foreach (var element in beams)
				ElementId id = element.Id;
				idc.Add(id);
			uidoc.Selection.SetElementIds(idc);
			uidoc.ShowElements(idc);
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @AGYEMANG.OFOSU,
I tried using your code and it works fine for me.
The problem may be with your bounding box.
Just increase the boundary of your bounding box and give it a try.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
AGYEMANG.OFOSU
it does not work. I am trying to get beams parallel to the view direction and are cut by the view plane but it does not work. I have tried
FAIR59
AGYEMANG.OFOSU
Thankfully I had seen your solution before and it worked liked a charm. Grateful.
