select elements witch cut by the view
glenncai
Message 1 of 10
glenncai
HI,
I'm looking for a way to hide all the framing members that are being cut on the section or elevation view.
currently I have to select them and hide them manually.
Is there any methods or properties that allows me to filter out the elements that cut by the view thru the  API?
I tried to google this and search the chm file for cut line but have no luck yet. any suggestions? Thanks.
Replies (9)
Message 2 of 10
glenncai
sorry for my funny typo. Woman Embarassed
Message 3 of 10
FAIR59
You can use a BoundingBoxIntersectsFilter.
BoundingBoxIntersectsFilter CutPlaneFilter = new BoundingBoxIntersectsFilter(_outline);
List<Element>  ElemsInCutPlane =
   new FilteredElementCollector(doc, ActiveView.Id)
      .WhereElementIsNotElementType()
      .WherePasses(CutPlaneFilter)
      .ToList<Element>();
where _outline is made from the points of a region in the cutplane , for instance the Crop Region
Message 4 of 10
desdinova
Hello gleencai
Did you find solution
I have a similar question
      .ToList<Element>();
Didn't work for më Thanks in advance. ...
Message 5 of 10
FAIR59
@desdinova
Sorry to hear that it doesn't work for you. Before posting a did a small scale test, and it worked fine.( 1 wall in empty project)  The "code" in my previous post, is intended as a roadmap / pseudocode.
this is my testing code:
            StringBuilder s = new StringBuilder();
            Document doc = revit.Application.ActiveUIDocument.Document;
            Autodesk.Revit.DB.View ActView = doc.ActiveView;
            XYZ pt1 = new XYZ(0, 0, 0);
            XYZ pt2 = new XYZ(0, 0, 100);
            XYZ pt3 = new XYZ(0, 100, 100);
            XYZ pt4 = new XYZ(0, 100, 0);
            Outline _outline = new Outline(pt1, pt3);
            _outline.AddPoint(pt2);
            _outline.AddPoint(pt4);
                   new FilteredElementCollector(doc, doc.ActiveView.Id)
                            .WhereElementIsViewIndependent()
                            .ToList<Element>();
            s.AppendLine(string.Format("{0} elements found",ElemsInCutPlane.Count));
            s.AppendLine();
            foreach (Element e in ElemsInCutPlane)
                s.AppendLine(string.Format("{0}  <{1}>   {2}", e.Name,e.Id,e.GetType()));
            TaskDialog.Show("debug", s.ToString());
            //using (Transaction t = new Transaction(doc, "test"))
            //    t.Start();
            //    SketchPlane _plane = SketchPlane.Create(doc, new Plane(XYZ.BasisX, XYZ.Zero));
            //    doc.Create.NewModelCurve(Line.CreateBound(pt1, pt3), _plane);
            //    t.Commit();
Message 6 of 10
Hi desdlinova
It works for me. The only problem I have is the outline of the crop region. I'm not able to make it under control.
Message 7 of 10
desdinova
Thanks for replies
I wonder is it possible to use section bounding box for outline
I try
ViewSection viewSection = doc.GetElement(uidoc.Selection.PickObject(ObjectType.Element)) as ViewSection;
BoundingBoxXYZ bb = viewSection.get_BoundingBox(null);
XYZ pt1 = bb.Max;
XYZ pt2 =bb.Min;
Outline _outline = new Outline(pt1, pt2);
List<Element> ElemsInCutPlane = new FilteredElementCollector(doc, doc.ActiveView.Id)
.ToList<Element>();
but it returns null.
Thanks again.
Message 8 of 10
FAIR59
It might work, but you'd have to project the 3D bounderies unto the cutPlane, while remembering / realising that BounderyBox.Min and Max are coordinates local to the bounderybox.  Furthermore I suspect that an Outline needs at least 3 points.
I have a solution following a different path, using the CropRegionShapeManager of the view.
    public class Cmd_SelectElemsInCutPlane : IExternalCommand
        public Autodesk.Revit.UI.Result Execute(ExternalCommandData revit,
        ref string message, ElementSet elements)
            List<CurveLoop>  _crop = ActView.GetCropRegionShapeManager().GetCropShape().ToList<CurveLoop>();
            CurveLoop cvLoop = _crop.First();
            List<XYZ> _cropPoints = new List<XYZ>();
            foreach( Curve cv in cvLoop)
                if (cv is Line)
                    _cropPoints.Add(cv.GetEndPoint(0));
                else
                    // redundant all curves in crop region are straight lines
                    List<XYZ> temp = cv.Tessellate().ToList<XYZ>();
                    temp.RemoveAt(temp.Count - 1);
                    _cropPoints.AddRange(temp );
            if (_cropPoints.Count < 3) return Result.Failed;
            Outline _outline = new Outline(_cropPoints[0], _cropPoints[1]);
            for (int i = 2; i < _cropPoints.Count; i++)
                _outline.AddPoint(_cropPoints[i]);
// if you need a bigger region just scale
//            _outline.Scale(100);
// simplefy the result using OfClass or OfCategory
                            .ToList<Element>();
            List<ElementId> IdsInCutPlane = new List<ElementId>();
// "postprocessing" here if needed
                IdsInCutPlane.Add(e.Id);
            revit.Application.ActiveUIDocument.Selection.SetElementIds ( IdsInCutPlane);
            return Result.Succeeded;
Message 9 of 10
desdinova
Thanks FAIR59;
It works like a charm....
Message 10 of 10
glenncai
FAIR59
Sorry for the late reply guys. It is hard to squeeze time when deadline is approaching. The solution that you provided is awesome. but for me I just have to modify it a little bit since I'm using Macro for testing. and It looks like List<CurveLoop> not working in Revit 2015. but is fine on company's Revit 2016. Thanks for your help.
		public void SelectCutElement()
			Document doc = this.ActiveUIDocument.Document;
			UIDocument uidoc = this.ActiveUIDocument;
				if (cv is Line)
				else
			string info = "";
			if (_cropPoints.Count > 3)
				List<Element> ElemsInCutPlane =	new FilteredElementCollector(doc, doc.ActiveView.Id).WhereElementIsNotElementType().WhereElementIsViewIndependent().WherePasses(CutPlaneFilter).ToList<Element>();
					info += e.Name;
					info += Environment.NewLine;
				uidoc.Selection.SetElementIds (IdsInCutPlane);
			TaskDialog.Show("info",info);
