HI,
I'm looking for a way to hide all the framing members that are being cut on the section or elevation view.
currently I have to select them and hide them manually.
Is there any methods or properties that allows me to filter out the elements that cut by the view thru the API?
I tried to google this and search the chm file for cut line but have no luck yet. any suggestions? Thanks.
Solved by FAIR59. Go to Solution.
You can use a BoundingBoxIntersectsFilter.
BoundingBoxIntersectsFilter CutPlaneFilter = new BoundingBoxIntersectsFilter(_outline);
List<Element> ElemsInCutPlane =
new FilteredElementCollector(doc, ActiveView.Id)
.WhereElementIsNotElementType()
.WherePasses(CutPlaneFilter)
.ToList<Element>();
where _outline is made from the points of a region in the cutplane , for instance the Crop Region
Hello gleencai
Did you find solution
I have a similar question
.ToList<Element>();
Didn't work for më Thanks in advance. ...
Sorry to hear that it doesn't work for you. Before posting a did a small scale test, and it worked fine.( 1 wall in empty project) The "code" in my previous post, is intended as a roadmap / pseudocode.
this is my testing code:
StringBuilder s = new StringBuilder(); Document doc = revit.Application.ActiveUIDocument.Document; Autodesk.Revit.DB.View ActView = doc.ActiveView; XYZ pt1 = new XYZ(0, 0, 0); XYZ pt2 = new XYZ(0, 0, 100); XYZ pt3 = new XYZ(0, 100, 100); XYZ pt4 = new XYZ(0, 100, 0); Outline _outline = new Outline(pt1, pt3); _outline.AddPoint(pt2); _outline.AddPoint(pt4); BoundingBoxIntersectsFilter CutPlaneFilter = new BoundingBoxIntersectsFilter(_outline); List<Element> ElemsInCutPlane = new FilteredElementCollector(doc, doc.ActiveView.Id) .WhereElementIsNotElementType() .WhereElementIsViewIndependent() .WherePasses(CutPlaneFilter) .ToList<Element>(); s.AppendLine(string.Format("{0} elements found",ElemsInCutPlane.Count)); s.AppendLine(); foreach (Element e in ElemsInCutPlane) { s.AppendLine(string.Format("{0} <{1}> {2}", e.Name,e.Id,e.GetType())); } TaskDialog.Show("debug", s.ToString()); //using (Transaction t = new Transaction(doc, "test")) //{ // t.Start(); // SketchPlane _plane = SketchPlane.Create(doc, new Plane(XYZ.BasisX, XYZ.Zero)); // doc.Create.NewModelCurve(Line.CreateBound(pt1, pt3), _plane); // t.Commit(); //}
Hi desdlinova
It works for me. The only problem I have is the outline of the crop region. I'm not able to make it under control.
Thanks for replies
I wonder is it possible to use section bounding box for outline
I try
ViewSection viewSection = doc.GetElement(uidoc.Selection.PickObject(ObjectType.Element)) as ViewSection; BoundingBoxXYZ bb = viewSection.get_BoundingBox(null); XYZ pt1 = bb.Max; XYZ pt2 =bb.Min; Outline _outline = new Outline(pt1, pt2); BoundingBoxIntersectsFilter CutPlaneFilter = new BoundingBoxIntersectsFilter(_outline); List<Element> ElemsInCutPlane = new FilteredElementCollector(doc, doc.ActiveView.Id) .WhereElementIsNotElementType() .WhereElementIsViewIndependent() .WherePasses(CutPlaneFilter) .ToList<Element>();
but it returns null.
Thanks again.
It might work, but you'd have to project the 3D bounderies unto the cutPlane, while remembering / realising that BounderyBox.Min and Max are coordinates local to the bounderybox. Furthermore I suspect that an Outline needs at least 3 points.
I have a solution following a different path, using the CropRegionShapeManager of the view.
public class Cmd_SelectElemsInCutPlane : IExternalCommand { public Autodesk.Revit.UI.Result Execute(ExternalCommandData revit, ref string message, ElementSet elements) { Document doc = revit.Application.ActiveUIDocument.Document; Autodesk.Revit.DB.View ActView = doc.ActiveView; List<CurveLoop> _crop = ActView.GetCropRegionShapeManager().GetCropShape().ToList<CurveLoop>(); CurveLoop cvLoop = _crop.First(); List<XYZ> _cropPoints = new List<XYZ>(); foreach( Curve cv in cvLoop) { if (cv is Line) { _cropPoints.Add(cv.GetEndPoint(0)); } else { // redundant all curves in crop region are straight lines List<XYZ> temp = cv.Tessellate().ToList<XYZ>(); temp.RemoveAt(temp.Count - 1); _cropPoints.AddRange(temp ); } } if (_cropPoints.Count < 3) return Result.Failed; Outline _outline = new Outline(_cropPoints[0], _cropPoints[1]); for (int i = 2; i < _cropPoints.Count; i++) { _outline.AddPoint(_cropPoints[i]); } // if you need a bigger region just scale // _outline.Scale(100); BoundingBoxIntersectsFilter CutPlaneFilter = new BoundingBoxIntersectsFilter(_outline); // simplefy the result using OfClass or OfCategory List<Element> ElemsInCutPlane = new FilteredElementCollector(doc, doc.ActiveView.Id) .WhereElementIsNotElementType() .WhereElementIsViewIndependent() .WherePasses(CutPlaneFilter) .ToList<Element>(); List<ElementId> IdsInCutPlane = new List<ElementId>(); foreach (Element e in ElemsInCutPlane) { // "postprocessing" here if needed IdsInCutPlane.Add(e.Id); } revit.Application.ActiveUIDocument.Selection.SetElementIds ( IdsInCutPlane); return Result.Succeeded; } }
FAIR59
Sorry for the late reply guys. It is hard to squeeze time when deadline is approaching. The solution that you provided is awesome. but for me I just have to modify it a little bit since I'm using Macro for testing. and It looks like List<CurveLoop> not working in Revit 2015. but is fine on company's Revit 2016. Thanks for your help.
public void SelectCutElement() { Document doc = this.ActiveUIDocument.Document; UIDocument uidoc = this.ActiveUIDocument; Autodesk.Revit.DB.View ActView = doc.ActiveView; List<CurveLoop> _crop = ActView.GetCropRegionShapeManager().GetCropShape().ToList<CurveLoop>(); CurveLoop cvLoop = _crop.First(); List<XYZ> _cropPoints = new List<XYZ>(); foreach( Curve cv in cvLoop) { if (cv is Line) { _cropPoints.Add(cv.GetEndPoint(0)); } else { // redundant all curves in crop region are straight lines List<XYZ> temp = cv.Tessellate().ToList<XYZ>(); temp.RemoveAt(temp.Count - 1); _cropPoints.AddRange(temp ); } } string info = ""; if (_cropPoints.Count > 3) { Outline _outline = new Outline(_cropPoints[0], _cropPoints[1]); for (int i = 2; i < _cropPoints.Count; i++) { _outline.AddPoint(_cropPoints[i]); } // if you need a bigger region just scale // _outline.Scale(100); BoundingBoxIntersectsFilter CutPlaneFilter = new BoundingBoxIntersectsFilter(_outline); // simplefy the result using OfClass or OfCategory List<Element> ElemsInCutPlane = new FilteredElementCollector(doc, doc.ActiveView.Id).WhereElementIsNotElementType().WhereElementIsViewIndependent().WherePasses(CutPlaneFilter).ToList<Element>(); List<ElementId> IdsInCutPlane = new List<ElementId>(); foreach (Element e in ElemsInCutPlane) { // "postprocessing" here if needed IdsInCutPlane.Add(e.Id); info += e.Name; info += Environment.NewLine; } uidoc.Selection.SetElementIds (IdsInCutPlane); } TaskDialog.Show("info",info); }
