Schedule TextSize
Schedule TextSize
fdkuenneke
Schedule TextSize
fdkuenneke
Hey all,
I was wondering what unit the:
ViewSchedule.GetTableData().GetSectionData(SectionType.Body).GetTableCellStyle(row, col).TextSize
property is. It appears to be pt, but the number found in the API does not mathematically convert well to the text size found in REVIT.
I'd say Revit was a chisel if it wasn't used as a hammer.
fdkuenneke
For the record, I should have mentioned that the font size found in REVIT is in inches, and Tammik's snooper can't access the method I am looking for (That or I am simply misusing it, which is more likely...).
jeremytammik
If RevitLookup does not enable you to explore the required property or method interactively, you can use other, more intimate database exploration tools such as the RevitPythonShell:
https://thebuildingcoder.typepad.com/blog/2013/11/intimate-revit-database-exploration-with-the-pytho...
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
