BrowserOrganisation Change vent
Kevin.Bell
Advisor Advisor
Kevin.Bell
I've create an addon which lists views to access some that I use regularly... I've now set it up to display as per the browser organisation for sheets - this all works well.
I need to update my list as the user chaqnges things so I've subscripbed to the DocumentChanged event with:
app.DocumentChanged += new EventHandler<Autodesk.Revit.DB.Events.DocumentChangedEventArgs>(onDocChanged);
I then check for changes to Views and BrowserOrganisation class using a filter:
            //Create filter for elements of type View
            ElementClassFilter viewFilter = new ElementClassFilter(typeof(View));
            //Create filter for elements of type BrowserOrganisaton
            ElementClassFilter orgFilter = new ElementClassFilter(typeof(BrowserOrganization));
            //Views Modified Action
            ICollection<ElementId> elesMod = e.GetModifiedElementIds(viewFilter);
            //BrowserOrganisation Modified Action
            ICollection<ElementId> orgMod = e.GetModifiedElementIds(orgFilter);
This works and I can detect when the user amends the BrowserOrganisation by changing some of its sorting.
My problem is that I cannot detect or work out what filter I should use to catch the event when the user sets the Browser organisation to something different.
The event fires, but the filters I have above miss whats changed. Anyone have any pointers on what to filter for to puck up the BrowserOrganisation change.
Thanks.
jeremytammik
Have you tried using DMU to detect that?
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.31
Jeremy Tammik
Developer Technical Services
The Building Coder
