Saving Events into Text File
Hi ,
I'm currently new to API , just started not long .
I've learn a code (attached) that will record the documentsaving event in a text file , display the user's ID and time saved .
However, I want to be able to save the textfile into Desktop instead of the TempFolder, and also I would like the Macro to run automatically instead of needing to run another macro for it to work .
Any help would be appreciated !
Thanks in advance
Aaron.Lu
A IExternalApplication is needed to start automatically when Revit starts.
http://help.autodesk.com/cloudhelp/2015/ENU/Revit-API/files/GUID-CEF0F9C9-046E-46E2-9535-3B9620D8A17...
as for desktop folder, try google
let's see what you've found 🙂
Aaron Lu
Developer Technical Services
Autodesk Developer Network
