Placing elements on wall
Message 1 of 8
Struggling to place an element on wall[second floor level] like switch , mirror light etc.
Tried several combinations of NewFamilyInstance but nothing led to place elements on wall. They seems to be fall very below the second floor level.
Thanks & Regards
Sanjay Pandey
Replies (7)
Message 2 of 8
Aaron.Lu
Dear, would you please attach the family file, so that I can try from my side?
Aaron Lu
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
Yes sure.
Please Find Attached.
Message 4 of 8
Aaron.Lu
try these 2 methods:
  • FamilyInstance NewFamilyInstance(Reference reference, XYZ location, XYZ referenceDirection, FamilySymbol symbol)
  • FamilyInstance NewFamilyInstance(Reference reference, Line position, FamilySymbol symbol)
for example:
Wall wall = null;
var references = HostObjectUtils.GetSideFaces(wall, ShellLayerType.Interior);
var reference = references.First();
RevitDoc.Create.NewFamilyInstance(reference, new XYZ(0, 0, 0), new XYZ(0, 0, 1), familySymbol);
Aaron Lu
Message 5 of 8
Still the same result.
Message 6 of 8
When I am trying to use this method
doc.Create.NewFamilyInstance(face, location, xrefdir, symbol);
the attached family Mirror Light fixture gets placed at the bottom of the wall and also its elevation property is disabled but when I manually place that family on the wall it fits correctly and and also elevtion property is enabled. and When I place the attached switch family [Switch board] via the above method it places in a surprising way.
screenshots follows:
switch placed via code . Note that elevation is grayed out/disabled
switch placed manually
Thanks & Regards
Message 7 of 8
Aaron.Lu
What about changing the parameter "Schedule Level" to a real level after creating
and then see if the parameter Elevation is editable?
Aaron Lu
Message 8 of 8
Tried and changed  "Schedule Level" to a real level still elevation is grayed out. but when cut and paste the instance created normally then it works perfectly fine.
I don;t know but it should be pretty simple
1. Get the face of the wall.
2. decide the fanily to palce
3. decide its location to lace
4 and then place it
what in the world am I doing wrong.
Thanks & Regards
Sanjay Pandey
