SaveAsCloudModel is taking more time
dayanand_rakte
dayanand_rakte
Below is my source code.
While debugging I found that below line of code
doc.SaveAsCloudModel(new Guid(hubId), new Guid(projectId), folderId, modelName);
is taking more time and its not stepping to next line .I am able to see the model on ACC but I am not able to get access of Revit Dekstop application as its in freezed state .
I have tested the same code for empty model its working fine. My current model size is 8.33 MB.
Please suggest .
Thanking you in anticipation.
public static async Task<bool> SaveAsCloudWorksharedModel(Document doc, string hubName, string projectName, string folderName , string modelName)
string hubId = await GetHubIdByName(hubName);
string projectId = await GetProjectIdByName(hubId, projectName);
string folderId = await GetFolderIdByName(hubId ,projectId, folderName);
hubId = hubId.Substring(2); // skipping prefix b.
projectId = projectId.Substring(2); // skipping prefix b.
try
if(doc.CanEnableCloudWorksharing())
doc.EnableCloudWorksharing();
return true;
catch (Exception ex)
throw;
return false;
ctm_mka
curious, is your intent to create a new model on ACC each time? how often are you running this? are you overwriting or creating it in a different location?
dayanand_rakte
I am uploading my local Revit model on cloud.This will happen on a button click event.Where I am doing some stuffs and uploading this model on cloud.
Now I am getting Exception "Internal Error..."
