Empty Project Browser.
protocolo4QA59
Observer Observer
protocolo4QA59
Observer
Observer
The Revit home screen is gray, I can open the files normally, but the project browser is empty, preventing me from opening views.
protocolo4QA59
Observer
Observer
u can help? pls!
@joaquim.moral
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @protocolo4QA59 ,
I read that shutting down your PC, restarting it, and then opening Revit may resolve the issue.
If this does not help, please note that this forum is specifically dedicated to programming and development using the Revit API. For questions related to product setup, optimization, usage, best practices, or other end-user support issues, you will likely receive more appropriate guidance in one of the non-API Revit product support forums.
For more information, please refer to the following link: https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
